Author Topic: New WERKSracing Tubular Front and Rear Adjustable Sway Bars group buy pre order!  (Read 115801 times)
New WERKSracing Tubular Front and Rear Adjustable Sway Bars group buy pre order special!!!
Another great new product for your Kappa that we are proud to release is our WERKSracing Kappa Tubular Front and Rear Adjustable Sway Bar Package!!!
Features all Made In the USA construction!
Durable powdercoated finish
Locking collars to keep left to right movement in check
10% stiffer than the ZoK bars
2 way adjustable front and 3 way adjustable rear
Tubular 1 3/8" x .188" Wall front and 1 1/8" x .188" Wall rear bars
Comes complete with polyurethane bushings, locking collars, brackets and lube
***Shown in standard black powdercoat***
***Optional custom powdercoat colors available for $35.00 per bar***
***Pre-order group buy special pricing of $300.00 for the front and rear set***
***After 11/1 bars will go up to list pricing which will be $400.00 per set***
Order here - http://www.performanceautowerks.com/catalog/product_info.php?products_id=1996
Zerk Grease fitting option = $20.00 for all 4 brackets.
Group buy List -
1) Sting Ya - P
2) Mean 327 - P - Installed FSB & RSB
3) Critter - P - Installed FSB & RSB
4) JoshMcMadMac - P - Shipped - RSB - 3/6/14
5) ChopTop - P - Shipped - RSB - 3/6/14
6) RandyRay - P - Shipped - RSB - 3/6/14
7) rlhammon - P - Shipped - RSB - 3/6/14
8) kartstud98 - P - Shipped - RSB - 3/6/14
9) royceu - P - RSB Available for pickup - 3/6/14
10) Treeman - P - Shipped - RSB - 3/6/14
11) numba41 - P - Shipped - RSB - 3/6/14
12) Tech_God - P - Shipped - RSB - 3/6/14
13) Sly bob - P - Shipped - RSB - 3/6/14
14) cdnite - P
15) Anthony H - Shipped - RSB - 3/6/14
Brackets, supplied grease and locking collars -
Triple adjustable rear bar ends -
Rear bar installed -
Front bar installed -
« Last Edit: March 06, 2014, 04:59:51 PM by werks »
Offline ophidia31
Always nice to see new stuff comming out still. But question. Does the 10% increase come from just the adjustability? Just thinking that the zok bars are 6mm wall thickness to the 4.7mm of your bars. But since the increase in size of yours over the zok bars, I would think the bars by themselves would be very similar IF the adjustability wasnt there?
2013 Grigio Abarth 500
Stiffness is achieved by more than just diameter and wall thickness, length, material and attachment point location also factor in.  On the inner adjustment point the stiffness is 10% stiffer than the Z0K bars, the outer points are at the ZoK stiffness, you are essentially getting 2 sets of bars in one!
« Last Edit: September 15, 2013, 10:28:10 AM by werks »
Offline cooper1340s
Will these fit on Solstice with LS3 conversion and full dual exhaust>
06 SLY, Sand&Steel, Formerly DDM Stage III Intercooled/Supercharged: NOW LS3/480 V8, Tremec 6 speed, 3.23 positraction Getrag differential, custom stainless steel true dual exhaust system w/high flow cats, carbon fiber rear valance, red powder coated calipers, DDMWorks Stage 1 brake upgrade, extra horn, garage door opener, customized fuse box cover, Red anodized engine covers, DDMWorks console, Lambo doors, clear bra, DDMWorks red racing backbone, car is de-badged.
Offline cdnite
Stiffness is achieved by more than just diameter and wall thickness, length, material and attachment point location also factor in.  On the inner adjustment point the stiffness is 10% stiffer than the Z0K bars, the inner points are at the ZoK stiffness, you are essentially getting 2 sets of bars in one!
Do you mean the inner most are 10% stiffer than Z0K and the outer most attachment points are equal to the Z0K? So the center hole would be ~5% stiffer than the Z0K?
Can I get them uncoated?
--Christian
Offline droptopsf98
Is 11/1 your pre-buy deadline or do you have another date in mind?  Or just plan on setting up the pre-buy for the first set quantity?
Offline GXP_Matt
Also interested in the answer to this question, and why 10% adjustment?  Was that just the most the stock non-adjustable endlinks allow?
Yes they will fit on an LS converted Kappa
Yes, that is what I meant, sorry I went back and corrected my typo...
Yes we can send a set uncoated, same price as we have a special deal set up with our coater for these bars.
--Christian
The group buy pre-order is to get the first set into production.  After the 11/1 date these will go up in price and swill be sold at $400.00 for the set.
Any stiffer just wasn't needed, we have tested our sway bar design on the track for the last year or so and experimented with ALL the different sway bars out there and this was the best offering we came up with, they really work well.
I'd have preferred a 12% increase, but oh well.
Offline critter
  • Married, 4 grandkids
That would be the metric increase!!!
Offline rlhammon
What is the bushing material?
I swapped out to the polyurethane bushings years ago, and LOVED the difference for autocross.  Granted, I have the entire suspension set (control arms and bars) installed, but really don't want to go back to rubber and loose any of the crispness I have gained in steering.
I'm very interested in these.  I would then have a set of Z0K bars to sell. :)
The bushing material is polyurethane
Offline rlhammon
Apparently I completely missed that the several times I read your post... because I see it's there now.  Sorry for asking the redundant question.
Offline royceu
Does this replace the Pro-Beam?
It replaces the factory sway bar.  The Pro-Beam is something completely different.
Offline ophidia31
Sooo... that would be a yes? lol But would these bars be available seperately? If anything I would probably be interested in just the rear to tame some of the understeer when I do get it.
List has been started!!!
Offline 50willie
Ill probably buy a set. But am not going to want to pay yet as Im moving out of state shortly and am not yet sure of ky new address.
Okay no problem, I can put you on the list and you can pay after you get your new address, sound okay?
GMADIGXP added to the list!!!
Let keep this group buy going!!!
