Author Topic: Big 3 Audio Upgrade - Power Cables - Ground - Alternator  (Read 19717 times)
Offline darrylba
« on: June 09, 2014, 08:23:20 AM »
I own a 2007 Saturn Sky. Has anyone done the Big 3 Audio upgrade, power cable, ground wire cable. So, how did u do it. It seem the toughest part would be adding the power cable. If someone has done it is there a post or link to the instructions.
db
Offline darrylba
« Reply #1 on: June 09, 2014, 08:56:07 AM »
Re: Big 3 Audio Upgrade - Power Cables - Ground - Alternator
« Reply #2 on: June 09, 2014, 09:22:47 AM »
It took me a whole 5 minutes to read and find what you're looking for. Start here:
http://www.kappaperformance.com/forum/index.php/topic,9021.0.html
Re: Big 3 Audio Upgrade - Power Cables - Alternator
« Reply #3 on: June 09, 2014, 11:34:39 AM »
Is this a repost?  See your previous post for some responses.
Welcome to the forum!
If you are experiencing any issues with the forum, you can always email the Boss:  kappaperformance@yahoo.com
« Reply #4 on: June 09, 2014, 11:37:48 AM »
Yes, it's a repost because apparently posting it once in the audio/ nav section where it belongs wasn't enough. Noobs...go figure...
« Reply #5 on: June 09, 2014, 11:57:20 AM »
Now now...be nice to the noobs!  We don't want to turn into that nasty other forum that is mean to its members, especially noobs!!!  :lol:
« Reply #6 on: June 09, 2014, 11:58:41 AM »
Yeah GJ, noobs don't know you are a pain in the @$$ to everyone.  Play nice.
« Reply #7 on: June 09, 2014, 01:15:42 PM »
+1
We want to try and encourage new members to join.  There is plenty of time to run them off later if need be. :lol:
« Reply #8 on: June 09, 2014, 02:50:53 PM »
+1
OK so we give them 5 posts and then we hijack their threads, heckle them, run them off, etc.  I like it!
Offline darrylba
« Reply #9 on: June 09, 2014, 03:26:44 PM »
Ok, guys, I made a honest mistake. I will take the jokes in stride.    :yay:
Offline darrylba
« Reply #10 on: June 09, 2014, 03:30:48 PM »
I too found this in 5 minutes too prior to posting. Show me where it talks about the big 3? Never the less thanks for that reminder on how to search.
Offline darrylba
« Reply #11 on: June 09, 2014, 03:40:43 PM »
Gentalman Jack, thanks for the welcome. I been on for about a year. I been able to find answers to questions I have in the past, thus no reason for me to comment or post untill the issue I have now. And I found these answers to past questions using the search facility. I wont post something unless I find the information I need. The keywords I tried did not get me the info I need, so that is why I posted. Anyways Jack, thanks again for the welcome.
db
« Reply #12 on: June 09, 2014, 05:24:42 PM »
Jeesh...you're not even a noob!  You're a lurker!!!  It's worse than we thought!!!!
I see you're an old pro over on the forum where the members are mean!  You already know the drill!
Welcome to KP!
Offline darrylba
« Reply #13 on: June 09, 2014, 09:08:53 PM »
I hawk95, yes, I hang around all these forums.  I am making progress now. Oh the beauty of back and forth. So much fun.
DB
« Reply #14 on: June 09, 2014, 09:31:01 PM »
FLOCK OF SEAGULLS!!!!
I wasn't mean!  It was someone else!
(For once)
« Reply #15 on: June 09, 2014, 09:33:10 PM »
Mean Helios
« Reply #16 on: June 09, 2014, 10:15:36 PM »
Meanies!!!!
« Reply #17 on: June 09, 2014, 10:16:47 PM »
Do we have a smartazz smiley? What is the indicator for smartazzness?
« Reply #18 on: June 09, 2014, 10:20:47 PM »
I think smartass is pretty much synonyms with SA or GJ.
« Reply #19 on: June 09, 2014, 10:25:19 PM »
DB
Yeah I like to jump in now and then, but mostly I just lurk.
I try to make zero worthwhile contributions and add no value of any sort to anything as often as possible. I'm just a post whore and attention loving, drama queen. It's not easy, but someone has to do it. It's why I post all the time.  :roll:
« Reply #20 on: June 09, 2014, 10:27:01 PM »
I see no smiley with either of your faces.
« Reply #21 on: June 09, 2014, 11:40:46 PM »
Maybe not but it's still a pretty good indicator.
« Reply #22 on: June 10, 2014, 06:48:39 AM »
Sorry about my smartazzness.  :sorry: :banghead: I'll try to be of more help.
« Reply #23 on: June 10, 2014, 07:00:36 AM »
The necessity to do a big 3 upgrade depends on what you plan on pushing. I'll assume that you plan on pushing equipment that will require a large current draw. Replacing the battery to chassis ground and chassis to engine block wires should be easy enough since they are both located (for the most part) right underneath the hood. The difficult one will be the wire from the positive connection on the battery to the alternator. I haven't looked at the alternator connection, but if the terminal post on the alternator will hold a large enough terminal lug it shouldn't be too difficult a task, IMO.
« Reply #24 on: June 10, 2014, 11:07:40 AM »
I guess another question is just how much add on equipment can you add to the Kappa given the space constraints?  Spicy/Spikey did a major audio upgrade including cutting out and changing the bulkhead behind the seats just to add space, not sure that he had any power supply problems though.
