Author Topic: New GXP/Z0K sway bar part number  (Read 190899 times)
Ben L
« Reply #50 on: July 01, 2009, 11:19:47 AM »
I hope so!  There is another CDC Summit Point Skidpad event on July 18.  Love to see you there.
The Daytona Coupe should be ready by then, but I am considering taking the Solstice out anyway, because the sealer they have on the pavement out there makes it not exactly 500+ rwhp friendly.  Also, I probably would log more 2009 championship points in the GXP (which I am used to) than in breaking in a brand new beast.
Unlike SCCA (which handicaps PAX strictly based on car classing), at CDC events, the handicap system is based on indexed times weighted according to: hp; whether you run R compound tires; and car weight.  Cobras get hammered in all categories, and move down compared to raw times.  Sols on good street tires (provided you credibly claim no more than 250 rwhp), the opposite.
To illustrate, I let a girl (good driver, wife of one of the top CDC drivers) drive my GXP at a CDC event in Woodbridge Saturday.   She pulled a 38.45, good for 26th overall, but after the street tire, weight and hp handicaps were factored in she moved UP ten places, to post a 16th place indexed finish in a field of 85 cars.
I drove Fast Freddie's Cobra in both am and pm runs. I logged a 38.00 best pass in the borrowed Cobra, 18th out of 85 overall in raw time, but got killed in index time, as the hp, tire, and weight factors pushed me DOWN 25 whole places.
For comparison, top three times for the day were a 34.65, a highly modified FWD Honda Civic, 34.85, Wade Chamberlain's supercharged Cobra, and Fast Freddies' Cobra (driven by Fred), 35.34.
Point is, Sols on good street tires index really well at CDC events.  You can move up a lot if you get a decent (top 25%) raw time.
So come out and play!
« Reply #51 on: July 01, 2009, 11:29:31 AM »
I think the 18th might work, weekend of my sons birthday maybe he will come along who knows.
Ben L
« Reply #52 on: July 01, 2009, 11:55:33 AM »
Sign up on CDC's website and drive that Goat . . .  Registration should open in a week or so . . .
www.capitaldrivingclub.com
« Reply #53 on: July 01, 2009, 01:05:13 PM »
It seems easier to sign up in person at the event, I will try and make it Summit is in my back yard.
« Last Edit: July 01, 2009, 01:57:33 PM by lil goat »
« Reply #54 on: July 01, 2009, 05:45:42 PM »
The ZOK package was tested in the track and since I like to do that once in a while, my feeling is to go with what the GM boys tested and found to work well.
After all T2 SCCA has been capture a couple of times.
I do not Autox any more, and do not plan to do it any time soon.
« Reply #55 on: July 02, 2009, 07:58:12 AM »
With all respect, LV, the SCCA HANDED T2 to Pontiac by granting it wider wheels and weight breaks, among other things, to what amounted to factory teams. That said, I recently received the Solstice Performance book and have already benefited. One thing they are DEAD WRONG on is their toe IN setting for the front for Solo. Also, just about everybody with GXP/Z0Ks in Solo are NOT using the Z0K front bar, and many of the 2.4 Z0Ks ditto. Simply too much understeer with the bigger front bars.
BTW, put on my just received Z0K rear bar. It was a NIGHTMARE as I had to R&R the trailer hitch. :banghead: :banghead: :censor: :censor: :mad: :mad:  While I was there the rear bearing packs came off to install the longer ARP studs to allow for wheel spacers to eliminate inner wheel well tire rub with the 315 Hoosiers (SCCA will not allow hammering the inner sheet metal). Other than dropping the MagnaFlow muffler on my face  :idiot: :cryin: :nuts: :cryin: :idiot: (ouch, and some ice under my right eye took care of the "mouse" that quickly developed) all went well. This car is SO easy to work on. It's fun.
« Reply #56 on: July 02, 2009, 08:03:01 AM »
I hate it when that happens!
« Reply #57 on: July 02, 2009, 08:06:50 AM »
Critter if you want my old bar you will need some 26mm bushings, Summit Racing has them.
« Reply #58 on: July 02, 2009, 08:08:45 AM »
I will order them next week, or maybe today.
« Reply #59 on: July 02, 2009, 08:37:18 AM »
I will bring your bar to the No Mod meet, you can't install it but you can look at it.
« Reply #60 on: July 02, 2009, 10:39:44 AM »
Sure hope you kept the old bushings, I cannot find greasable 26mm bushings on their website  and I have been through about 25 pages of their listings.
« Reply #61 on: July 02, 2009, 10:50:43 AM »
Even non greaseable ones in urethane instead of rubber would be better, and yes I have the bushings. Here is the deal, 25mm is considered 1" 27 mm in considered 1 1/16. I believe U-238 said the 27mm were to big for the stock bar, that's what size it's supposed to be according to spec, I might try the 25 mm  should be pretty damn close, better a bit tight than loose. One inch is actually 25.4 mm, I bet the stock bar is a one inch bar. I found the 1" on Jegs but most likely on Summit too
« Last Edit: July 02, 2009, 11:07:08 AM by lil goat »
« Reply #62 on: July 02, 2009, 01:46:27 PM »
25's I saw on several pages, the only 26's where for civics or corvettes :)
« Reply #63 on: July 02, 2009, 02:07:07 PM »
I would try 25 mm as they are most likely a bit over 25 mm if they are 1". the 26 mm were a lot more expensive too WTF, makes no sense to me. I do have the factory junk rubber ones, they are in good shape but as you would notice just the change to urethane even without changing the bar I would go urethane. :goat:
« Reply #65 on: July 02, 2009, 07:56:32 PM »
Thanks 238,  I ordered the greaseable 25mm's on the goat's recommandation.  The 26's are all dry
« Reply #66 on: July 02, 2009, 11:49:21 PM »
OK, the ZOK bar showed up today. Hope to get it installed tomorrow.
Oh, and the new bar is 1mm larger than the stock one, the 27mm bushing fit just fine. So, no, you cannot try and sneak it across as a stock bar. (Not that I would have tried anyway...)
« Reply #67 on: July 03, 2009, 07:08:51 PM »
OK, the new sway bar is installed. Not a difficult install, but it was painful at times.
Made a dramatic difference in how the car handles. No more turn the wheel, wait a tic for the effect. Used to be, if you moved the wheel back and forth a little at highway speed, the car would continue straight. (unless you held it there for a bit, then it would turn. Now the car responds to input more readily. It's a bit looser in the corners of course. Some turns I used to take at WOT now require partial throttle.
On the whole, I think the car should have come like this stock, or at least as an option. The reviews of these cars that claim the steering is numb compared to a Miata ought to try a ZOK rear bar equipped Kappa.
Oh, and like the Goat I noticed that the rear end seems a bit more planted on launches. It's a little tougher to squeal the tires now.
I'd love to try an A/X the car with this. Might try joining Ben and the Goat next weekend.
I wonder what impact the new bar will have in the rain?
« Reply #68 on: July 03, 2009, 08:09:31 PM »
I did some driving today and tried to nail down what all the suspension goodies do for my car. I think I have it/ When I bought the car I would throw it around corners not very precise but it worked and I could go very fast. After the DDM, stuff it was more precise but still throwing it around. Then came the coilovers, MUCH more precise less throwing more driving, then the Z0K bar. It seemed to tie things together, like it was the missing piece. Can I drive any faster now, I don't know. But it is much easier to drive fast, I feel like I am much more in control and it takes far less effort to drive very fast. I am now excited about the Auto X. I feel like I am much better able to control the car. It has far better manners over rough roads. I certainly agree it should have come with the Z0K bar much less body roll.
« Reply #69 on: July 03, 2009, 08:10:05 PM »
None. The lever on the right side of the steering column has some impact on the rain.  :rofl: :poke: :lol: :yay: :D :woohoo:
« Reply #70 on: July 03, 2009, 08:25:34 PM »
Oh, one very important thing to add: The end links? The bolt was a torx bit-it was a hex. Used an allen key, worked great.
Goat, sounds like when are cars were stock we felt about the same way. Sometimes I could get the car to "hook" in a turn, and you could feel the car cut it's way through a turn. But, it was difficult to get the car to do this through the entire turn. With the new sway bar, it's no longer a problem.
Oh, and it helped kill the rear end's tendency to roll after coming out of a corner.
Bob, you think maybe some rain-x might help with that too? :D
« Reply #71 on: July 03, 2009, 09:58:18 PM »
Oh, sure. Spray it all over the treads so they will shed the water !!!!!!!!!!!!   :lol: :rofl: :idiot:
Next question ............................
« Reply #72 on: July 04, 2009, 03:59:09 PM »
Mine were torx maybe they changes be a damn good thing if they did torx was a pain :goat:
« Reply #73 on: July 04, 2009, 05:48:20 PM »
2007 Redline.
Allen, not torx.
Offline GregGXP
  • Go NAK3D
« Reply #74 on: July 04, 2009, 07:48:26 PM »
2007 Redline. Allen, not torx.
That could explain why the Torx was a pain for LG  :rofl:
2008 GXP, Mean
DDM Backbone:
