Author Topic: What did you do to your Kappa today!  (Read 1262587 times)
« Reply #4575 on: July 05, 2011, 09:28:14 PM »
Tried to hardwire a V1 to the mirror.  Found out the hard way that there is no switched power there.  So, it's temporarily connected to constant power.  Just now, I saw the thread for the A-pillar gauge power connection.  I'm going to have to run a wire from the interior fuse box.
« Reply #4576 on: July 05, 2011, 11:12:12 PM »
I have to admit I have always liked the look of the eyelids. Got any extra "silver pearl" vinyl you didn't use? :lol:
As a matter of fact I do. It fades toward the end of the roll, but maybe i can get another set out of it. If you are serious about it, I am sure we can work it out this fall in ohio if you decide to show up :)
« Reply #4577 on: July 06, 2011, 08:43:41 AM »
Thanks Miller!!!
« Reply #4578 on: July 06, 2011, 09:24:15 AM »
Shiny
Do you know what you just agreed to?
« Reply #4579 on: July 06, 2011, 09:27:17 AM »
Shiny
I ain't a scared!  Wait... What did I agree to?
You think if I let Miller tinker with my car she'll catch the dreaded "Miller Gremlins"? :lol: :poke:
« Reply #4580 on: July 06, 2011, 09:46:34 AM »
I'm just wondering if him tinkering with your car means you will have to tinker with his little gremlin.
« Reply #4581 on: July 06, 2011, 10:37:10 AM »
Im not touching anything mechanical...so she should be ok.
I mean she didnt catch the gremlins when I helped SA do her heated seats!
« Reply #4582 on: July 06, 2011, 07:53:16 PM »
Having just the rear might the back of the car tighter...almost like you're one with the car.  Adding the front made the car more linear and there is almost 0 body roll at all...front end seems to be easier to control....as if more emphasis has been put on driver input.
Finally someone agrees with me!
« Reply #4583 on: July 06, 2011, 08:41:17 PM »
Sorry Kenny. As much as I'd like to stiffen the front sway bar it isn't happening without a means to stiffen the rear to correct the understeer. With the Pro Beam installed I've been trusting the car more and it's definitely pretty close to neutral. When taking traffic circles both tires sing out at the same time, no more plowing! I'm going to try and get DDM's front brace sometime soon.
« Reply #4584 on: July 06, 2011, 08:44:21 PM »
Crank up the rear shocks baby! I just turned mine a half turn.
Offline Excelsior
« Reply #4585 on: July 06, 2011, 08:55:13 PM »
That almost sounds NSFW!
BTW - I think 100000 views is going to surpass the 5000 replies
« Reply #4586 on: July 06, 2011, 08:59:48 PM »
I was aware of this, but all the other ways to say it were even worse...
« Reply #4587 on: July 06, 2011, 09:44:59 PM »
I currently have the rears at 360 degrees
And the fronts at 180 degrees from all soft.
I also only have the rear ZOk.
I do have some front lean but barely and it seems to aid with with the turn in. I currently like it but would like to compare and contrast.
I wonder if the LV brace will reduce roll but not affect the turn in I like
« Reply #4588 on: July 06, 2011, 10:00:53 PM »
Probably not a noticeable amount, it serves a different purpose.
Not sure how lean would help turn in, or else racecars would have tons of body roll :)
« Reply #4589 on: July 06, 2011, 10:08:36 PM »
Not sure if this will explain it well enough
Instead of plowing and understeer, the car leans some but has oversteer.
« Reply #4590 on: July 06, 2011, 10:29:23 PM »
Yes, that makes sense. But there are other ways to control the balance of the car, such as shocks, springs and tire pressure. So what I've been suggesting to folks is to go with the stiffer front bar and reduce the understeer via those other methods.
« Reply #4591 on: July 06, 2011, 11:03:59 PM »
I'm going to stick with "If it's not broken don't fix it" for now. :D
I'm happy with the setup, and till I've got another vehicle to take over daily driver duties I don't foresee doing enough to the car to justify upgrading the suspension further. Once the focus goes from DD to race car all bets are off.
« Reply #4592 on: July 07, 2011, 10:42:27 AM »
Had to wipe the rain spots off of it. We are in the monsoon season here in the desert! High humidity and overnight lows of 85! Feels like I am back in Florida... :gaah:
« Reply #4593 on: July 08, 2011, 07:30:06 AM »
Thinkin' of all the work that I'm gonna have getting the bugs off the front of mine and getting her cleaned up when I get home from my Cabot Trail trip.
« Reply #4594 on: July 08, 2011, 08:34:18 AM »
Use Poorboys' Bug Squash, they'll wipe right off :D  :buff:
« Reply #4595 on: July 08, 2011, 08:52:43 AM »
I will be picking mine up at lunchtime and will be doing a debugging later this afternoon.   :gaah:
Once the Sol is all cleaned up, we'll be enjoying Cruise Night together and probably getting into trouble!  Oh wait...must be good...will have Solstice and have to work early in the morning.   :banghead:
Offline krelubot
« Reply #4596 on: July 08, 2011, 09:01:31 AM »
Had the dealer change the oil and program new keyfobs.  Patiently waiting for the state to print/stamp out and mail my personalized tag.
« Reply #4597 on: July 08, 2011, 09:25:45 AM »
Hope to take my car to lunch today... last chance to drive it for a while since we'll be making the summer trek to the Florida out-laws.
(Yes, I will wave to Donkeytown as we drive through on I95 :donkey:)
Offline JimVonBaden
« Reply #4598 on: July 08, 2011, 10:31:00 AM »
High humidity? In Vegas? I lived there ten years and it never went above 50%, IN the middle of a gully washer rain storm.
I also lived in Florida, and now In Virginia. High heat and humidity are a daily thing.
When I left Vegas in 89 it had been eight months of no rain. I do not miss it at all, though I go often to visit my daughter there.
Jim :cool:
PS I haven't touched my Sky in a week.
Offline sallysky
« Reply #4599 on: July 08, 2011, 02:22:09 PM »
I replaced the shift knob with a new one from JPM! I also installed a decal on the side where I got keyed. I am not sure if I like it or not yet but it does mask the scratch repair.
2008 RL Bluestone/Tan/Black Leather "Sally"
"SKY4JOY"
5 Speed
Vision Wheels
Stubby
Custom Etched Glass Windscreen
Kenwood DNN991HD
Alpine PDX-v9 Amp Infinity Kappa Front & Tweets Kicker Rears and sub
Brake Light Decal
Painted Calipers
Silver Marker Bulbs
RPI GT exhaust
GMPP CAI & Turbo upgrade
Color Matched Badges
DDM backbone & venom brace, Pro Beam
JPM Dash, console, trunk liner, shifter
Norms rear facia, side skirts, front splitter
Custom Painted Hood Liner
Blue powder coated pipes
VDI Hinges - Halo- HID
