Author Topic: LIPSTICK'S 800hp first LNF compound turbo/engine build!  (Read 359982 times)
« Reply #400 on: September 21, 2012, 06:19:20 PM »
AAAA that's what it was.
All I remember is tall people conversing and I was mesmerized by all the parts.
« Reply #401 on: September 21, 2012, 07:29:47 PM »
You should have been, it was the only place that had parts for your foreign car.
« Reply #402 on: September 21, 2012, 11:40:05 PM »
Did they have a TRE for a Dodge Ram?
« Reply #403 on: September 22, 2012, 12:17:10 AM »
I think Kelu was searching for one of those in the rest room.  Elff was helping by turning the lights on for him.  Or maybe it was all just a plot by Madalina to distract Elff so that she could shock him with that little kids toy she had on the dash of her car. :poke:
« Reply #404 on: September 22, 2012, 01:10:14 AM »
Damn, I forgot about this, it requires one more trip to bring that to Casa de Elf :D
« Reply #405 on: September 22, 2012, 11:48:27 AM »
If I was going to Elff's Halloween party I know what costume I would have to have, it would scare the hell out of someone we know.
« Reply #406 on: September 22, 2012, 12:33:19 PM »
You might got shot at the door!!!!
« Reply #407 on: September 22, 2012, 02:03:53 PM »
This is what i think of every time Elff describes the devilbaby.
http://www.youtube.com/watch?v=oKGKB5bc9DU&feature=youtube_gdata_player
« Reply #408 on: September 22, 2012, 02:41:46 PM »
UPDATE:  Walbro 400 fuel pump to replace the lpfp.....will not fit, uggghhhh.
we'll just use a walbro 255lph fuel pump since it's just a drop-in pump for the lpfp replacement.
Walbro 400 fuel pump will be just dedicated for the auxillary injectors.
« Last Edit: September 22, 2012, 02:46:29 PM by SKY888 »
« Reply #409 on: September 22, 2012, 04:02:10 PM »
I love that commercial, and you are spot on.   I think that clown is the flower Demon's brother
« Reply #410 on: November 15, 2012, 09:51:55 PM »
Update:
BTF is still working on fabbing the secondary fuel tank that will be placed inside the trunk.
We are hoping that everything will be finished by the week-end after Thanksgiving.
Then tuning begins....
for the past few months, wife and I have been very busy moving into the new house and unpacking.   Also been attending pregnancy/baby classes.
Also working with Median Magazine to feature my car.   They ended up having a 5-page spread  article for LIPSTICK.
I'm hoping that the car will be on the cover of Median Magazine once the build is finally finished, and have another feature that will include more about the build, fabrication, tuning, dyno and  etc.
MEDIAN MAGAZINE  will be the best source for local high performance automotive news in the Northeast Region of America. All the top shops. The big builds. Products and services from local companies. Tech articles. It's all gonna be there.
check out the facebook account:  http://www.facebook.com/mobileprotection#!/MedianMag?fref=ts
sorry for the blurry photos of the pages of Lipstick:
« Reply #411 on: November 16, 2012, 02:49:46 PM »
you do realize that bates does not make main studs nor bearings.... right? lol
Looks good. Glad it is getting the attention! maybe you can have a sky of mythical lore similar to the WOTM supras or the Full Race GTRs :)
Also did you ever figure out what the actual motor compression is with the k1 rods? (not that its a bad thing to be on the higher end of compression for your project... more ponies that way!)
« Reply #412 on: November 16, 2012, 03:50:09 PM »
My K1 rods as well as greaseyjockey's and BTF were custom made by K1 rods....to produce the exact same compression as stock LNF rods (exactly same length).
I know that the other k1 rods that most LNF owners bought off-the-shelf are a bit longer  and producing a tad higher compression tho....
« Reply #413 on: December 01, 2012, 03:36:16 PM »
Liquid Black powdercoat for the charge pipes and turbo compressors
« Reply #414 on: December 01, 2012, 08:59:14 PM »
Is this thing ever going to actually run?  (we need a smiley with the guy tapping a watch)
« Reply #415 on: December 01, 2012, 10:13:34 PM »
 . All the parts are impressive BUT Do you have a Date as to when you Road Test the BEAST
    Tony The Tiger would say   ITS Looks  GRRRR8
« Reply #416 on: December 02, 2012, 12:09:51 AM »
"someday"........it will run.....lol
« Reply #417 on: May 20, 2013, 09:21:08 AM »
I communicated to BTF lately since I may have some money again....so he can start working on it again....lol
Here are some updates:
Last month, he actually started the engine.  He revved the throttle, the motor rocked over and snapped the nipple of the canister valve since its so close to the ABS.  so that needs to be worked on.
He also discovered that due to the system size, that the custom end tank of the radiator needs to be modified due to fitting issues.   This will be a dual pass radiator system.
He also found out that the drainback slope issue to be solve with the primary turbo being too low and up front.
And lastly having to go around with lots of hot stuff of the compound set-up that needs to be managed in order not to melt important wires/hoses/etc.
« Reply #418 on: May 20, 2013, 09:56:20 AM »
Welcome Back DADDY!!!!!
Offline Racer_X
« Reply #419 on: May 20, 2013, 07:56:25 PM »
Yeah welcome back, brah!!
2008 Sly GXP (Z0K) Custom Tune, Dejon Precision 5557B Kit, Wiseco/ARP/K1 Built Bottom End, AEM Meth Injection, SPEC Stage III Clutch, DDMworks Backbone, Kappasphere ReBar, DDM Crossbrace, Custom Front Splitter, HKS SSQV, NORMS ZR-1 fenders, Cobalt SS BBK.
414rwhp/ 436tq @ 26.5psi
« Reply #420 on: May 20, 2013, 09:14:01 PM »
custom intake manifold w/ port injectors installed.....with custom 3" intake pipe
also using a 2.4 throttle body
Vibrant Quick release boost braces will be welded on the pipes from primary turbo to intercooler pipe which uses 2" to 3" coupler.
these will keep coupler from popping off at high boost pressures.    Every 10 psi of boost = 80lbs of pull force on 3" pipe.   We are planning to go around 45-60psi :)
but everything else we'll use 3" Vibrant vanjen clamps
we need to really think about all these kind of stuff with this kind of build.   Every lil aspect will make it last longer
« Last Edit: May 20, 2013, 11:13:01 PM by SKY888 »
Offline xrbvx
« Reply #421 on: July 04, 2013, 03:43:41 PM »
Man this is very impressive, can't wait to see it running!
« Reply #422 on: July 04, 2013, 10:48:19 PM »
That is (1) Bad A** Nasty  looking Engine .Its a good thing you have sponsors or the Baby or you two wouldn't eat much. LOL  I would like to be there when you fire it up and test it ! .
« Reply #423 on: October 19, 2013, 07:12:15 PM »
Just some few updates:
Well only another 47 heatshields to fab and a gajillion miles of wiring to sort.   Due to the tons of hot tubing inside the engine bay, melting of important wiring is the biggest concern.
The oil drains are now .085" wall aluminum tubing, the power steering system and reservoir was relocated and reservoir swapped out for a WRX reservoir.
The water neck on the top of the radiator was changed because it was rubbing and the glass coolant tube and charge pipe weren't parallel to each other.
Mounted the secondary fuel pressure regulator directly to the rail instead of on the frame (that's a no-no as per racing rules).  Now working on a bracket for the fuel pressure damper that has been free hanging on the DI pump thus far.
Brackets are getting welded to the top of the intercooler core  since it  precluded the use of the crash beam, there is nothing holding the top of the front bumper cover and it flops around
The pass thru for the engine harness between the primary header and the low pressure turbine feed is the trick here, it's fabbed from aluminum chargepipe tubing with a flare mouth aimed at the radiator fan to not only heatshield, but aircool the insulated harness
« Reply #424 on: October 21, 2013, 01:59:45 PM »
some photos (SORRY FOR THE VERY DIRTY IMAGES!)
Aeromotive fuel pressure regulator for the secondary fuel rail.   Werks Intake manifold below with port injectors.
the Purdy GT4294r
Boost brace for support
DEI gold heat shield to cover the important wires and hoses
Burns Stainless Race Mufflers with SOLO custom 3" exhaust (3" on all pipings!)
« Last Edit: October 21, 2013, 07:23:09 PM by SKY888 »
