Author Topic: LIPSTICK'S 800hp first LNF compound turbo/engine build!  (Read 359880 times)
Offline Yogi
« Reply #550 on: October 30, 2015, 05:44:36 PM »
Antonio -
Injecting water into a compressor inlet is not a good idea.  The water will tear up the compressor blades.  (I used to work on Industrial Gas Turbines)
Aircraft jet engines have titanium strips soldered onto the leading edges of compressor blades so that rain will not damage them.  Your compressor wheel is prolly aluminum?
Yogi
2008 Saturn Sky Red Line
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Monsoon Sound System
Leather Seats
« Reply #551 on: October 30, 2015, 05:56:43 PM »
Antonio -
Yogi
yogi...thank you for the heads up!   I appreciate your concerns.
and I know because of your background, you guys probably encountered a lot of issues.
in turbo applications, I've only seen one compressor that was damaged among my research before.  I believe its a rotary turbo who encountered it.  But besides him, a lot of tuners have been doing pre-turbo spray.
I believe big water droplets can cause the destruction of compressor blades.  That's why the jet engines get damaged due to large rain droplets :(
but spraying using moisture in vapor form....will not be as harmful.
what are your thoughts?
Offline Yogi
« Reply #552 on: October 30, 2015, 06:09:11 PM »
If it were mine, and I had put as much work and money into it, I would not do it.  The only way that it MAY work is if the air is hot enough to vaporize the water before entering the compressor intake.  If you have ANY droplets, large or small, they will damage your compressor blades for sure.
Yogi
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Leather Seats
« Reply #553 on: October 30, 2015, 06:30:29 PM »
thanks for the input Yogi.
I think the biggest difference between the aircraft jet engines...getting hit by large rain droplets......................and my compound set-up is temperature.
up there in the sky.....before the water hits the aircraft jet engines.......the water's temp...is not as hot compared to temp in between the turbo compressors?
with my compound set-up, without measuring the temps yet (before it hits the intercooler), I'm assuming air temp out of big turbo is around 350 degrees and the small turbo bumps it up around 400 degrees.  Injecting around 1500cc of straight water to take that 100 degrees out of the temp between compressors
and like what I mentioned in my previous statement......we are spraying moisture in vapor form during ...........only on high boost
« Last Edit: October 30, 2015, 06:38:35 PM by SKY888 »
Offline Yogi
« Reply #554 on: October 30, 2015, 06:51:44 PM »
You're quite welcome, Antonio.
Temperature and PRESSURE!  at higher pressures, you need higher temperatures to vaporize the water.  Think about the pressure cap on the radiator and how it raises the boiling point of the coolant in the engine.
Yes, and the atmospheric pressure is lower too.
How can you be sure that you are spraying "only vapor"?
Yogi
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Leather Seats
« Reply #555 on: October 30, 2015, 07:03:17 PM »
Oh it's spraying water.
But due to high boost pressure & 300-400 degree temperature between turbos, the water gets vaporized before hitting the compressor blade?
Thoughts?
Offline Yogi
« Reply #556 on: October 30, 2015, 07:09:07 PM »
Thoughts?
The only way to know for sure is to take the temperature and pressure and look it up in a steam table.  I wish that I hadn't thrown out my college textbooks when I moved after divorce.
Yogi
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Leather Seats
« Reply #557 on: October 30, 2015, 07:12:08 PM »
Damn Yogi, why make me double guess my plans! Lol!
Thanks for all the stuff I learned today.
I'll discuss with BTF
Offline Yogi
« Reply #558 on: October 30, 2015, 07:17:57 PM »
Again, you're welcome, Antonio!
Have a look at these diagrams:
http://www.engineeringtoolbox.com/boiling-point-water-d_926.html
As long as you STAY above the boiling point line, you should be OK.
Yogi
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Leather Seats
« Reply #559 on: October 30, 2015, 07:27:57 PM »
i might not....who knows?
as long as the engine is strong.....and I can have it to drive it!   its been a million of years! :)
I totally understand.  I am simply enjoying driving mine right now.  Only have a couple more weeks until that's not a good idea to drive these cars in our area.
Offline Jim
« Reply #560 on: October 30, 2015, 08:37:30 PM »
I actually had pretty good luck and results spraying before the turbo on one of my previous setups. It ran several years with no issues.
« Reply #561 on: October 30, 2015, 09:29:37 PM »
Yogi
Thanks, this will be useful!
« Reply #562 on: October 30, 2015, 09:31:13 PM »
Jim, a couple of questions:
1.) did u spray just water? Or 50-50?
2.) did u spray in an angle? Or did u spray straight towards center of compressor?
Offline Jim
« Reply #563 on: October 30, 2015, 11:01:52 PM »
I sprayed water at a 90 degree angle.
it's not uncommon to see carbureted setups that draw fuel through the compressor. I had a draw through setup on an aircooled VW engine that ran like a scalded ape before switching to fuel injection.
« Reply #564 on: October 30, 2015, 11:19:14 PM »
Oh nice Jim!
U still have that car?
The guy that I mentioned on my first post, Kevin Jewer, he inspired me to do compounds. He had an 8 sec , RwD DSM compound turbo car. He currently sprays meth inter-stage.
4 nozzles ! :)
Offline Jim
« Reply #565 on: October 31, 2015, 12:23:51 AM »
 I got rid of the car for one with more creature comforts like the Sky has. Heat, AC, seatbelts and airbags....
Offline Yogi
« Reply #566 on: October 31, 2015, 10:56:06 AM »
One last thing that I forgot to mention:  The pressures in the charts and tables that I linked to above are ABSOLUTE pressures, NOT "GAUGE" pressures.  To convert from gauge pressure to absolute, add +14.7 PSI or +one BAR.
Yogi
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Leather Seats
« Reply #567 on: October 31, 2015, 02:27:19 PM »
Yogi
Yes!   :)
« Reply #568 on: October 31, 2015, 02:29:04 PM »
today, started using the secondary injectors spraying VP M1 methanol
M1 methanol + water + careful programming of transition = DELTA P!
GT42 is the light blue line/green for turbine.
Red is intake manifold pressure, yellow is turbine pressure 1
Note the green line in the top graph, that is MAF lbs/min. It has been flattened in the CAL to reflect the M1 systems addition to the total fuel load. The white line at the bottom Graph however is raw MAF frequency and truly should reflect mass flow changes... Although it slowly increases with RPM it seems to plateau more or less once 32 psi is achieved and the transition occurs of turbos.
If you run it setup for absolute mode on the primary gate (PR High in green graph #4) and keep that a steady 2-1 PR, system response is faster, but Delta P overall is negative by a half Bar or so. The twist comes with the MAF freq more or less is the same in either mode, having a positive delta or negative at the cyl head.
« Last Edit: October 31, 2015, 02:34:49 PM by SKY888 »
« Reply #569 on: November 01, 2015, 12:39:31 PM »
Hi yogi, if u look at the big turbo's compressor outlet, the water nozzle is installed (L-bend).
Water will be sprayed there and will travel at least 3 feet of tubing with 3-4 bends to reach the compressor inlet of the small turbo.
So the water nozzle is not directly in front of the compressor blades of the small turbo unlike some pre-turbo sprays that you usually see (directly in front & very close to the compressor blades).
So I'm thinking that by the time the water mist, due to temperature/pressure/distance/speed/bends/etc, there will be no big water droplets hitting the compressor blades, since it will be all changed into water vapor by then.
« Reply #570 on: November 01, 2015, 12:50:50 PM »
Btw the pure water on the LP stage seems to be working well so far. Its tied to LP side pressure and that is reflected in the data stream. Havent had any misfire issues thus far
Offline Yogi
« Reply #571 on: November 01, 2015, 12:53:57 PM »
Yes.  The distance and the bends should help.  As long as you STAY above the lines in those graphs that I quoted, you should be OK.  The only other potential problem that I can see is if there is a pressure surge that condenses the water.  However, any increase in pressure sufficient to condense the water or prevent it from vaporizing would likely only be a "spike" of very short duration, I would hope.
Yogi
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Leather Seats
Offline Yogi
« Reply #572 on: November 01, 2015, 12:55:40 PM »
Glad to hear!
Yogi
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Leather Seats
« Reply #573 on: November 03, 2015, 05:17:30 PM »
Initial dyno run at mustang dyno
440whp at 33psi
It is as far as it can go today without changing the LP turbo gate spring.
« Reply #574 on: November 03, 2015, 09:54:45 PM »
baby steps........since a lot of stuff going on with the interactions of the two turbos.
Need to be careful
at 35ish psi
still has a lot of bugs to fix............and will at least boost 40-45psi.
