Author Topic: Solstice Recessed Grills  (Read 299448 times)
Offline Wartie
Re: Solstice Recessed Grills
« Reply #25 on: November 01, 2012, 02:31:36 PM »
I think we got it worked out, but if not I will take you up on it.
Thanks Joe!
Dave
The file issue has been handled.  :yay:
« Reply #26 on: November 01, 2012, 03:07:00 PM »
Sweet! You don't have the cad file for the GXP bumper do ya' by chance?
Offline Wartie
« Reply #27 on: November 01, 2012, 03:16:25 PM »
Unfortunately, no. Might have to take a cast off a GXP and an NA to find out the difference.
« Reply #28 on: November 01, 2012, 03:39:14 PM »
So just curious how many people want a set of these?
« Reply #29 on: November 01, 2012, 04:45:18 PM »
I'm interested if cheap.
Offline EarthNTX
« Reply #30 on: November 01, 2012, 05:28:22 PM »
Me too. I really like them alot :)
Ride it like you mean it.
« Reply #31 on: November 01, 2012, 05:50:58 PM »
I want a set but if they are printed would quantities be an issue?     :idk:
« Reply #32 on: November 01, 2012, 05:52:01 PM »
Sorry Dave but I was referring to DDM Dave.
« Reply #33 on: November 01, 2012, 06:59:56 PM »
Wartie's name is the same as yours Bob :poke:
He was just relaying what Dave had told us that he only has the cad file for the NA.
Hey DBG do you still have that cracked GXP front bumper cover off of Sal's car and maybe a set of grills?
« Reply #34 on: November 01, 2012, 07:33:41 PM »
I knew that too...    :gaah:
Sorry Wartie.
Offline Wartie
« Reply #35 on: November 01, 2012, 07:48:50 PM »
Sorry "Frank"  :lol: but the answer is the same. He does not either. BTW, Dave was my dad's name.  :cool:
And I have a spare set of grilles from an '06
« Reply #36 on: November 01, 2012, 08:52:44 PM »
Bob,
 Some up close pictures would be a great help, maybe hold a tape measure in the picture for reference. I am also taking a stab at this. I could really use a depth or recess measurement as well.
Agreed we need to get an idea of how far the grills are recessed.
Dave as per our agreement here is my attempt at payment
Will that work?
« Reply #37 on: November 01, 2012, 09:00:52 PM »
Maybe ChopTop will chime in.
« Reply #38 on: November 02, 2012, 07:38:59 AM »
Need clarification.  Pics or access to the uninstalled set?
I'm not even sure what type of composite Rudy used, it's similar to plaster paris.  That's the reason the installation taps break, there's no flexibility in the tabs due to the composite they were molded in.
Whereas the OEM plastic grill and tabs are molded in the same type of plastic but the taps still have a little flexibility that allows for repeated installation or removal.
Also, Rudy design is two parts*.  The outer recessed inset grill with molded in tabs, and the inner separate hexagon grill.  Which is why you either have to use silicon or fine screws to hold them inside the outer recessed grill.
*four actual pieces.  L/R recessed grill, plus L/R hexagon grill.
« Last Edit: November 02, 2012, 07:43:29 AM by ChopTop »
Offline Wartie
« Reply #39 on: November 02, 2012, 07:52:12 AM »
That is very interesting about the two part design, that was actually one of my thoughts on a design. SA is taking the lead on the design, I will let him chime in on the grilles. Access to uninstalled grilles would probably help him the most.
« Reply #40 on: November 02, 2012, 09:04:15 AM »
The two piece design is nice in the fact that it's easy to paint the grills a diffent color than the outside ring. I found that worked well in my case and they look great installed as long as you don't look too close.   :2c:
Here's what they looked like installed.
http://www.kappaperformance.com/forum/index.php/topic,4298.msg58003.html#msg58003
« Reply #41 on: November 02, 2012, 09:07:56 AM »
I think that statement says it all.
« Reply #42 on: November 02, 2012, 09:11:50 AM »
I'd be interested in paying a few bucks into a pot via PayPal to help with shipping and development costs to help bring these to fruition.
I was going to pull the recessed grills off the car this winter to modify the mounting system to use screws to mount them to the bumper and to have the outer rings repainted. Now I think I'll hold off until we see how this goes.  :drool:
« Last Edit: November 02, 2012, 09:15:59 AM by Sly Bob »
« Reply #43 on: November 02, 2012, 11:08:17 AM »
With regard to how much they are recessed I need to know how far from the outer flange the honeycomb is set back.
As far as one part or two parts that is yet to be determined.
« Reply #44 on: November 02, 2012, 08:17:26 PM »
You should be able to see from the picture what I need is how far back is the grill moved.  Once I get that it shouldn't be too hard to draw in the missing part.
« Reply #45 on: November 02, 2012, 08:22:29 PM »
How difficult would it be to do alternatives to the recessed honeycomb.  For example vertical lines (a La Morgan or old Jag)?
« Reply #46 on: November 02, 2012, 08:24:20 PM »
Just have to draw it but it could be done.  Production cost would probably be the big factor.
« Reply #47 on: November 02, 2012, 10:27:42 PM »
Ahhh - I thought they were being plastic-printed, so the design was to be the only cost delta.  My bad.
« Reply #48 on: November 03, 2012, 12:00:39 AM »
I guess that could be a means of production too.  Once we get a model finished up we can look into things like that.
« Reply #49 on: November 03, 2012, 05:39:08 AM »
Looks like the sides of the rings could be a little bit tapered or sloped and the grill a little smaller. Here's a close up of the rings on the BB.
http://www.solsticeforum.com/forum/f111/recessed-grill-46595/index22.html#post871119
